查看: 1467|回复: 7
Free allegro skill file:Fixed/Unfixed
发表于 2004-11-1 12:12:34 | 显示全部楼层 |阅读模式
All,
I have wroten the fixed/unfixed skill program.Now share to everyone.It is free skill program.
Because 15.2 has the funcion to fixed/unfixed by icons.It is only suitable at the Allegro 14.0,14.2,15.1.
If you have any query,please contact with me by email.
Gordon431@hotmail.com,
Gordon_working@126.com
Mobil:13715284426
发表于 2004-11-1 12:19:50 | 显示全部楼层
Thanks!!
发表于 2004-11-15 18:57:32 | 显示全部楼层
出现如下,错误:
E- *Error* axlFormDisplay: argument #1 should be any user-defined (other) type (type template = "o") - nil
 楼主| 发表于 2004-11-16 08:32:48 | 显示全部楼层
Maybe it is wrong path for your fixed form file.
Please place these two files in your pcbenv folder.
发表于 2004-11-17 10:39:25 | 显示全部楼层
I didn't see the file yet, only one suggestion (to Mr. Liang):
if you have some form files(hope not too complicated), better attached it into the .il file, then you'll never worrying about where is the form file, and it also make it easier for the beginner (only one file need to be noticed).
anyway, thanks Liang for the sharing.
发表于 2004-11-18 11:28:34 | 显示全部楼层
你的檔案不是一般的文字敘述檔
 楼主| 发表于 2004-11-23 08:34:41 | 显示全部楼层
以下是引用RichardLC在2004-11-17 10:39:25的发言:
Thanks Richard for giving me the suggestion.
This fixed form was auto-generated by my auto-create form skill program.It is easy for me to create the form.
I try to attach the form file into *.il file in future,Thanks!
发表于 2011-1-26 12:44:18 | 显示全部楼层
money  money  money
GMT+8, 2025-5-15 19:57 , Processed in 0.136970 second(s), 20 queries .
