查看: 835|回复: 1
求教DRC检查问题
发表于 2005-3-11 10:31:40 | 显示全部楼层 |阅读模式
原用9.2版本画的原理图,DRC时没问题,可现用10.1打开,检查却有问题了。显示:
Checking Pins and Pin Connections
-------------------------------------------------- Checking Schematic: 4-DECODER_PROC -------------------------------------------------- Checking Electrical Rules
Checking for Unconnected Nets
Checking Off-Page Connections
Checking for Duplicate References
Check Bus width mismatch
-------------------------------------------------- Checking Schematic: MAINBOARD -------------------------------------------------- Checking Electrical Rules ERROR: [DRC0004] Possible pin type conflict SCH4,+3V3OP Output Connected to Power MAINBOARD, root (13.30, 4.00)
-------------------------------------------------- Checking Schematic: 1-PREAMP -------------------------------------------------- Checking Electrical Rules ERROR: [DRC0004] Possible pin type conflict MVREF2 Output Port Connected to Power 1-PREAMP, PREAMP (7.10, 8.10) WARNING: [DRC0004] Possible pin type conflict RFVCC Passive Port Connected to Passive Port 1-PREAMP, PREAMP (18.50, 5.30)
-------------------------------------------------- Checking Schematic: 3-DECODER -------------------------------------------------- Checking Electrical Rules
-------------------------------------------------- Checking Schematic: 2-SERVO -------------------------------------------------- Checking Electrical Rules
这是为什么啊?朋友知道吗?
我是用“place hierarchical block"画的分页符
发表于 2005-3-17 10:05:17 | 显示全部楼层
我没出现过这样的错误,我一直用的都是place Off-Page connector.帮你顶一下。
GMT+8, 2025-5-16 11:27 , Processed in 0.155367 second(s), 19 queries .
