查看: 5204|回复: 20
7件在用餐后不要做的事
发表于 2005-3-21 07:53:37 | 显示全部楼层 |阅读模式
*Don't smoke- Experiment from experts proves that smoking a cigarette after meals is comparable to smoking 10 cigarettes (chances of cancer is higher). *不要用餐后抽烟
-专家的实验证实用餐后抽烟比一般时间抽10根香烟有更高的致癌机率。 *Don't eat fruits immediately - Immediately eating fruits after meals will cause stomach to be bloated with air. Therefore take fruits 1-2 hours after meal or 1 hour before meal. *用餐后不要立即吃水果
-用餐后立即吃水果将导致胃部因空气而肿胀。
因此在用餐后的2小时或是用餐前1小时吃水果是比较理想的。 *Don't drink tea - Because tea leaves contain a high content of acid. This substance will cause the Protein content in the food we consume to be hardened thus difficult to digest. *不要在用餐后喝茶
-因为茶叶通常含有高酸性。
这种酸性物质将导致我们所摄取食物中所含的蛋白质变硬,
因此会比较难消化。
*Don't loosen your belt - Loosening the belt after a meal will easily cause the intestine to be twisted & blocked. *用餐后别松开你的腰带
-用餐后立即松开腰带将让你的肠子容易纠结和阻塞。
(这个观念怪怪的,不晓得在下有无翻译错误)
*Don't bathe - Bathing will cause the increase of blood flow to the hands, legs & body thus the amount of blood around the stomach will therefore decrease. This will weaken the digestive system in our stomach. *不要在餐后洗澡
-洗澡时会使得血液流向手、脚和我们身体的其它部位,
因此会减少胃部中的血液量,
这将会使得我们胃部的消化能力变差。
*Don't walk about - People always say that after a meal walk a hundred steps and you will live till 99. In reality this is not true. Walking will cause the digestive system unable to absorb the nutrition from the food we intake. *饭后不要散步
-大家总是说"饭后走100步可以活到99岁"。
但是那个观念是错误的,
用餐后的走动将使我们的消化系统没有足够能力,
从我们所摄取的食物中吸收足够的营养。
*Don't sleep immediately - The food we intake will not be able to digest properly. Thus will lead to gastric & infection in our intestine. *用餐后不要立即睡觉
-这样我摄取的食物将没有办法得到适当的消化,
因此可能导致胃部和肠部的感染。 *****************************************************************
发表于 2005-3-25 11:49:30 | 显示全部楼层
These are good ideas!
发表于 2006-3-13 12:58:13 | 显示全部楼层
I will don't do it again!!!
发表于 2007-8-8 17:25:41 | 显示全部楼层
thanks
发表于 2007-8-9 08:59:18 | 显示全部楼层
不错,顶一下!感谢楼主!
发表于 2007-9-27 19:33:48 | 显示全部楼层
尽量吧!!!!!!!!!!!!!!
发表于 2007-10-17 15:39:14 | 显示全部楼层
等我有兴趣的时候就来顶顶。。。。。ok
发表于 2007-10-17 15:39:48 | 显示全部楼层
等我有兴趣的时候就来顶顶。。。。。ok
发表于 2007-10-17 15:40:07 | 显示全部楼层
等我有兴趣的时候就来顶顶。。。。。ok
发表于 2007-10-17 15:40:25 | 显示全部楼层
等我有兴趣的时候就来顶顶。。。。。ok
GMT+8, 2024-5-17 15:19 , Processed in 0.310650 second(s), 19 queries .
