查看: 6641|回复: 33
IBIS Modeling CookBook For IBIS V4.0
发表于 2005-9-17 16:27:16 | 显示全部楼层 |阅读模式
刚刚发布,来自IBIS Open Forum,说明了生成IBIS V4模型的方法和若干细节,Very Good!
 楼主| 发表于 2005-9-17 16:40:09 | 显示全部楼层
Release Note:
The IBIS Open Forum is pleased to announce the availability of the IBIS Modeling Cookbook for Version 4.0! A substantial expansion of the 1997 version, this document provides detailed explanations for many aspects of the IBIS specification, and provides recommendations for extracting buffer data and properly using it to create IBIS models. Subjects covered include:
- use of several common IBIS 3.2 and 4.0 keywords and features - clamp adjustment techniques for internal terminations - differential buffer treatment under IBIS - pre-emphasis modeling techniques - tips on matching of V-t and I-V table data - C_comp extraction
and many others.
The document, in several formats, is available at the following URL:
http://www.eda.org/ibis/cookbook/
The Cookbook was a collaborative effort by several volunteers through the Cookbook Task Group of the IBIS Open Forum. Many thanks to them for their hard work over the last year.
发表于 2005-9-17 23:37:50 | 显示全部楼层
thanks .
could you do me a favour to answer the following question ?
http://www.pcbbbs.com/viewthread.php?tid=81587
发表于 2006-4-24 21:36:26 | 显示全部楼层
xiexie,yixiazai
发表于 2006-4-25 15:30:40 | 显示全部楼层
非常好,我一直在找
发表于 2006-4-27 17:07:00 | 显示全部楼层
不错,顶一下!感谢楼主!
发表于 2006-5-3 12:39:12 | 显示全部楼层
是e 文的吗?
发表于 2006-5-5 09:27:51 | 显示全部楼层
Thank you!
发表于 2006-5-10 01:59:37 | 显示全部楼层
感謝了~希望可以看到更多IBIS的細節~
发表于 2006-5-11 13:42:47 | 显示全部楼层
up to up
GMT+8, 2024-6-10 13:09 , Processed in 0.158655 second(s), 20 queries .
