查看: 1245|回复: 11
[推荐]FPC物料中英文对照
发表于 2005-10-23 04:55:09 | 显示全部楼层 |阅读模式
FPC 基 材
1、基材:base material 2、层压板:laminate 3、覆金属箔基材:metal-clad bade material 4、覆铜箔层压板:copper-clad laminate (CCL)
5、单面覆铜箔层压板:single-sided copper-clad laminate 6、双面覆铜箔层压板:double-sided copper-clad laminate
7、复合层压板:composite laminate 8、薄层压板:thin laminate 9、金属芯覆铜箔层压板:metal core copper-clad laminate 10、金属基覆铜层压板:metal base copper-clad laminate 11、挠性覆铜箔绝缘薄膜:flexible copper-clad dielectric film 12、基体材料:basis material 13、预浸材料:prepreg 14、粘结片:bonding sheet 15、预浸粘结片:preimpregnated bonding sheer 16、环氧玻璃基板:epoxy glass substrate 17、加成法用层压板:laminate for additive process 18、预制内层覆箔板:mass lamination panel 19、内层芯板:core material 20、催化板材:catalyzed board ,coated catalyzed laminate 21、涂胶催化层压板:adhesive-coated catalyzed laminate 22、涂胶无催层压板:adhesive-coated uncatalyzed laminate 23、粘结层:bonding layer 24、粘结膜:film adhesive 25、涂胶粘剂绝缘薄膜:adhesive coated dielectric film 26、无支撑胶粘剂膜:unsupported adhesive film 27、覆盖层:cover layer (cover lay) 28、增强板材:stiffener material 29、铜箔面:copper-clad surface 30、去铜箔面:foil removal surface 31、层压板面:unclad laminate surface 32、基膜面:base film surface 33、胶粘剂面:adhesive face 34、原始光洁面:plate finish 35、粗面:matt finish 36、纵向:length wise direction 37、模向:cross wise direction 38、剪切板:cut to size panel 39、酚醛纸质覆铜箔板:phenolic cellulose paper copper-clad laminates(phenolic/paper CCL) 40、环氧纸质覆铜箔板:epoxide cellulose paper copper-clad laminates (epoxy/paper CCL) 41、环氧玻璃布基覆铜箔板:epoxide woven glass fabric copper-clad laminates 42、环氧玻璃布纸复合覆铜箔板:epoxide cellulose paper core, glass cloth surfaces copper-clad laminates 43、环氧玻璃布玻璃纤维复合覆铜箔板:epoxide non woven/woven glass reinforced copper-clad laminates 44、聚酯玻璃布覆铜箔板:ployester woven glass fabric copper-clad laminates 45、聚酰亚胺玻璃布覆铜箔板:polyimide woven glass fabric copper-clad laminates 46、双马来酰亚胺三嗪环氧玻璃布覆铜箔板:bismaleimide/triazine/epoxide woven glass fabric copper-clad lamimates 47、环氧合成纤维布覆铜箔板:epoxide synthetic fiber fabric copper-clad laminates 48、聚四乙烯玻璃纤维覆铜箔板:teflon/fiber glass copper-clad laminates 49、超薄型层压板:ultra thin laminate 50、陶瓷基覆铜箔板:ceramics base copper-clad laminates 51、紫外线阻挡型覆铜箔板:UV blocking copper-clad laminates
基材材料
1、A阶树脂:A-stage resin 2、B阶树脂:B-stage resin 3、C阶树脂:C-stage resin 4、环氧树脂:epoxy resin 5、酚醛树脂:phenolic resin 6、聚酯树脂:polyester resin 7、聚酰亚胺树脂:polyimide resin 8、双马来酰亚胺三嗪树脂:bismaleimide-triazine resin
9、丙烯酸树脂:acrylic resin 10、 三聚氰胺甲醛树脂:melamine formaldehyde resin 11、多官能环氧树脂:polyfunctional epoxy resin 12、溴化环氧树脂:brominated epoxy resin 13、环氧酚醛:epoxy novolac 14、氟树脂:fluroresin 15、硅树脂:silicone resin 16、硅烷:silane 17、聚合物:polymer 18、无定形聚合物:amorphous polymer 19、结晶现象:crystalline polamer 20、双晶现象:dimorphism 21、共聚物:copolymer 22、合成树脂:synthetic
23、热固性树脂:thermosetting resin 24、热塑性树脂:thermoplastic resin 25、感光性树脂:photosensitive resin 26、环氧当量:weight per epoxy equivalent (WPE) 27、环氧值:epoxy value 28、双氰胺:dicyandiamide 29、粘结剂:binder 30、胶粘剂:adesive 31、固化剂:curing agent 32、阻燃剂:flame retardant 33、遮光剂:opaquer 34、增塑剂:plasticizers 35、不饱和聚酯:unsatuiated polyester 36、聚酯薄膜:polyester 37、聚酰亚胺薄膜:polyimide film (PI) 38、聚四氟乙烯:polytetrafluoetylene (PTFE) 39、聚全氟乙烯丙烯薄膜:perfluorinated ethylene-propylene copolymer film (FEP) 40、增强材料:reinforcing material 41、玻璃纤维:glass fiber 42、E玻璃纤维:E-glass fibre 43、D玻璃纤维:D-glass fibre 44、S玻璃纤维:S-glass fibre 45、玻璃布:glass fabric 46、非织布:non-woven fabric 47、玻璃纤维垫:glass mats 48、纱线:yarn 49、单丝:filament 50、绞股:strand 51、纬纱:weft yarn 52、经纱:warp yarn 53、但尼尔:denier 54、经向:warp-wise 55、纬向:weft-wise, filling-wise 56、织物经纬密度:thread count 57、织物组织:weave structure 58、平纹组织:plain structure 59、坏布:grey fabric 60、稀松织物:woven scrim 61、弓纬:bow of weave 62、断经:end missing 63、缺纬:mis-picks 64、纬斜:bias 65、折痕:crease 66、云织:waviness 67、鱼眼:fish eye 68、毛圈长:feather length 69、厚薄段:mark 70、裂缝:split 71、捻度:twist of yarn 72、浸润剂含量:size content 73、浸润剂残留量:size residue 74、处理剂含量:finish level 75、浸润剂:size 76、偶联剂:couplint agent 77、处理织物:finished fabric 78、聚酰胺纤维:polyarmide fiber 79、聚酯纤维非织布:non-woven polyester fabric 80、浸渍绝缘纵纸:impregnating insulation paper 81、聚芳酰胺纤维纸:aromatic polyamide paper 82、断裂长:breaking length 83、吸水高度:height of capillary rise 84、湿强度保留率:wet strength retention 85、白度:whitenness 86、陶瓷:ceramics 87、导电箔:conductive foil 88、铜箔:copper foil 89、电解铜箔:electrodeposited copper foil (ED copper foil) 90、压延铜箔:rolled copper foil 91、退火铜箔:annealed copper foil 92、压延退火铜箔:rolled annealed copper foil (RA copper foil) 93、薄铜箔:thin copper foil 94、涂胶铜箔:adhesive coated foil 95、涂胶脂铜箔:resin coated copper foil (RCC) 96、复合金属箔:composite metallic material 97、载体箔:carrier foil 98、殷瓦:invar 99、箔(剖面)轮廓:foil profile 100、光面:shiny side 101、粗糙面:matte side 102、处理面:treated side 103、防锈处理:stain proofing 104、双面处理铜箔:double treated foil
发表于 2005-10-25 13:25:27 | 显示全部楼层
不错!支持
发表于 2005-10-25 14:28:45 | 显示全部楼层
辛苦老兄了,支持一下。
 楼主| 发表于 2005-10-26 03:49:12 | 显示全部楼层
多谢楼上同仁的支持与理解![em05]
发表于 2005-10-27 14:49:28 | 显示全部楼层
thank you!
发表于 2005-10-27 16:19:10 | 显示全部楼层
非常感谢!!
发表于 2005-10-28 13:54:29 | 显示全部楼层
[em08][em08][em05]
 楼主| 发表于 2005-12-4 06:09:48 | 显示全部楼层
共同的资源大伙享用是不是?[em24]
发表于 2005-12-12 10:13:35 | 显示全部楼层
bucuo
 楼主| 发表于 2005-12-12 23:57:34 | 显示全部楼层
这么好的东西希望给予加精华
谢谢你了版主!
[em24]
GMT+8, 2025-5-20 12:53 , Processed in 0.138744 second(s), 19 queries .
