查看: 3382|回复: 4
新手发布几个FTP资源,请GGJJ们笑纳!
发表于 2005-11-24 21:20:23 | 显示全部楼层 |阅读模式
地址:ftp.altera.com
远端路径:/outgoing/release/quartusii_50_pc.zip
匿名登录
FlashFXP v3.1.11 build 1070 [BETA RELEASE]
心海e站 http://www.hrtsea.com
WinSock 2.0
[左] 正在连接到 ftp.altera.com -> DNS=ftp.altera.com IP=66.35.227.4 PORT=21
[左] 220 ftp.altera.com FTP server ready.
[左] USER anonymous
[左] 331 Guest login ok, send your complete e-mail address as password.
[左] PASS (隐藏)
[左] 230 Guest login ok, access restrictions apply.
[左] SYST
[左] 215 UNIX Type: L8
[左] FEAT
[左] 500 'FEAT': command not understood.
[左] REST 100
[左] 350 Restarting at 100. Send STORE or RETRIEVE to initiate transfer.
[左] REST 0
[左] 350 Restarting at 0. Send STORE or RETRIEVE to initiate transfer.
[左] CWD /outgoing/release/
[左] 250 CWD command successful.
[左] PWD
[左] 257 "/outgoing/release" is current directory.
[左] TYPE A
[左] 200 Type set to A.
[左] PASV
[左] 227 Entering Passive Mode (66,35,227,4,180,128)
[左] 正打开数据连接 IP: 66.35.227.4 端口: 46208
[左] LIST -al
[左] 150 Opening ASCII mode data connection for /bin/ls.
[左] 226 Transfer complete.
[左] 列表完成: 20 KB 于 3.61 秒 (5.6 KB/秒)
[左] TYPE I
[左] 200 Type set to I.
[左] PASV
[左] 227 Entering Passive Mode (66,35,227,4,137,52)
[左] 正打开数据连接 IP: 66.35.227.4 端口: 35124
[左] RETR quartusii_50_pc.zip
[左] 150 Opening BINARY mode data connection for quartusii_50_pc.zip (577253082 bytes).
 楼主| 发表于 2005-11-24 21:39:42 | 显示全部楼层
名称:江北水城社区影视 100K
日期:10.31
地址:ftp://bbs.lcinfo.cn:happygift@61.156.38.49:21212
账号:
密码:
[左] 正在连接到 61.156.38.49 -> IP=61.156.38.49 PORT=21212
[左] 连接失败 (连接被拒)
[左] 正在延迟 10 秒, 之后将尝试第 1 次重新连接
[左] 正在连接到 61.156.38.49 -> IP=61.156.38.49 PORT=21212 (第 1 次尝试)
[左] 220 欢迎访问江北水城社区---http://bbs.lcinfo.cn---,下载帐号及密码请查询影视FTP资源版块公告---http://bbs.lcinfo.cn/dispbbs.asp?boardID=30&ID=14106&page=1---
[左] USER bbs.lcinfo.cn
[左] 230 User logged in, proceed.
[左] SYST
[左] FEAT
[左] 211-Extension supported
[左] CLNT
[左] MDTM
[左] MDTM YYYYMMDDHHMMSS[+-TZ];filename
[左] SIZE
[左] SITE PSWD;EXEC;SET;INDEX;ZONE;CHMOD;MSG
[左] REST STREAM
[左] XCRC filename;start;end
[左] 211 End
[左] CLNT FlashFXP 3.1.11.1070
[左] 200 Noted.
[左] PWD
[左] 257 "/" is current directory.
[左] TYPE A
[左] PASV
[左] 227 Entering Passive Mode (61,156,38,49,7,229)
[左] 正打开数据连接 IP: 61.156.38.49 端口: 2021
[左] 数据 Socket 错误: 连接超时
[左] 列表错误
[左] PASV
[左] 227 Entering Passive Mode (61,156,38,49,7,235)
[左] 正打开数据连接 IP: 61.156.38.49 端口: 2027
[左] LIST -al
[左] 421 Connection timed out - closing.
[左] LIST
[左] 连接丢失: 61.156.38.49
[左] SYST
[左] FEAT
[左] CLNT
[左] MDTM
[左] SIZE
[左] REST STREAM
[左] 211 End
[左] 200 Noted.
[左] CWD /
[左] 250 Directory changed to /
[左] PWD
[左] TYPE A
[左] PASV
[左] 227 Entering Passive Mode (61,156,38,49,11,12)
[左] 正打开数据连接 IP: 61.156.38.49 端口: 2828
[左] LIST -al
[左] 列表完成: 204 字节 于 4.69 秒 (0.0 KB/秒)
[左] CWD 江北水城社区[bbs.lcinfo.cn]影视FTP#1
[左] 250 Directory changed to /江北水城社区[bbs.lcinfo.cn]影视FTP#1
[左] PWD
[左] 257 "/江北水城社区[bbs.lcinfo.cn]影视FTP#1" is current directory.
[左] PASV
[左] 227 Entering Passive Mode (61,156,38,49,11,28)
[左] 正打开数据连接 IP: 61.156.38.49 端口: 2844
[左] LIST -al
[左] 列表完成: 627 字节 于 12.09 秒 (0.1 KB/秒)
 楼主| 发表于 2005-11-24 21:42:08 | 显示全部楼层
名称:老古开发网
日期:10.31
地址:ftp://laogu.com:laogu.com@ftp.laogu.com
账号:
密码:
WinSock 2.0
[左] 正在连接到 ftp.laogu.com -> DNS=ftp.laogu.com IP=218.15.154.51 PORT=21
[左] 220 Serv-U FTP Server v5.2 for WinSock ready...
[左] USER laogu.com
[左] 331 User name okay, need password.
[左] PASS (隐藏)
[左] 230-欢迎来到老古开发网的FTP服务器
[左] 230-服务器已经运行了 3 天,7小时46分
[左] 230-目前有566位在线
[左] 230-上载总量: 5765954 K字节
[左] 230-下载总量: 257873240 K字节
[左] 230-上传文件数: 1023
[左] 230-下载文件数: 34901
[左] 230-平均带宽: 918.025 K字节每秒
[左] 230-当前带宽: 932.290 K字节每秒
[左] 230-IP地址: 59.40.43.156
[左] 230-最大可用磁盘空间61440256 KB
[左] 230-已经使用空间51061031 KB
[左] 230-剩余空间10379224 KB
[左] 230-如果密码变更请登陆http://www.laogu.com/ftp.asp查询新密码!!!
[左] 230-只允许上传电子,硬件方面的内容。
[左] 230-禁止上传电影,mp3等非电子硬件类内容。
[左] 230-
[左] 230-
[左] SYST
[左] FEAT
[左] CLNT
[左] MDTM
[左] SIZE
[左] REST STREAM
[左] MODE Z
[左] 211 End
[左] 200 Noted.
[左] PWD
[左] TYPE A
[左] MODE Z
[左] 200 MODE Z ok.
[左] PASV
[左] 227 Entering Passive Mode (218,15,154,51,39,52)
[左] 正打开数据连接 IP: 218.15.154.51 端口: 10036
[左] LIST -al
[左] 226-Maximum disk quota limited to 61440256 kBytes
[左] Used disk quota 51061031 kBytes, available 10379224 kBytes
[左] 列表完成: 876 字节 于 9.44 秒 (0.1 KB/秒)
发表于 2010-9-7 22:53:35 | 显示全部楼层
一个都用不了
发表于 2010-9-15 00:03:03 | 显示全部楼层
一个都用不了
lygo 发表于 2010-9-7 22:53
    你的锄头太长了!!!五年前的都挖出来了,佩服佩服!!!!
GMT+8, 2024-5-7 22:05 , Processed in 0.865408 second(s), 19 queries .
