查看: 1836|回复: 5
请教一个建cdb的问题
发表于 2006-1-3 15:59:03 | 显示全部楼层 |阅读模式
请问一下怎么建立zuken cr5000(bd)的库文件啊,因为画原理图,做layout都要用到库文件.
我这儿指的是,把zuken cr5000(bd)装好以后,一点也没有库文件.(什么*.prf *.pkg等等都没有,也就是机器上面只有zuken.).在这样的情况下,库文件是怎么一步一步建立的.
请各位大侠指点,最好能详细点,谢谢~!
发表于 2006-1-3 16:26:22 | 显示全部楼层
请问你们为什么要用CR5000呢?
是DESIGN HOUSE吗?
你问这个问题是最基础的也是最难的,如果把配置文件搞定的话那么你已经把CR5000掌握的差不多了.
 楼主| 发表于 2006-1-4 08:29:40 | 显示全部楼层
不是,我们是手机pcb设计.
cdb是韩国作好的,我们直接拿过来用. 我想自己坐一下试试.
 楼主| 发表于 2006-1-4 09:37:30 | 显示全部楼层
以下是引用syncretic在2006-1-4 9:06:53的发言:
简单,跟CADSTARE很类似的,
cadstare我没用过啊.能详细讲解一下吗?
发表于 2006-1-5 08:49:08 | 显示全部楼层
找到LIBRARY.RSC后打开编辑
# Library Resource File for CR-5000
# Note: Pathname should be enclosed by double quotation marks("").
# Note that the description methods are different between when
# you use libraries in a UNIX machine from a Windows machine
# and when you use libraries in a Windows machine.
# Part library file path
# (Windows -> UNIX) Ex "node1:/master/lib/cdbzuken.prt"
# (Windows -> Windows) Ex "N:\\master\\lib\\cdbzuken.prt"
Part {
# write pathname here.
# Package library file path
# (Windows -> UNIX) Ex "node1:/master/lib/cdbzuken.pkg"
# (Windows -> Windows) Ex "N:\\master\\lib\\cdbzuken.pkg"
Package {
# Footprint library file path
# (Windows -> UNIX) Ex "node1:/master/lib/cdbzuken.ftp"
# (Windows -> Windows) Ex "N:\\master\\lib\\cdbzuken.ftp"
Footprint {
# Library Searcher directory path
Searcher {
# write pathname here. Ex "N:\\master\\lib\\searchdata"
# Technology library file path
# (Windows -> UNIX) Ex "node1:/master/lib/technology.tch"
# (Windows -> Windows) Ex "N:\\master\\lib\\technology.tch"
Technology {
# Design rule library directory path
# note: Add the suffix ".rul" to the DesignRule directory name.
DesignRule {
# write pathname here. Ex "N:\\master\\lib\\designrule.rul"
# Manufacture rule library file path
# (Windows -> UNIX) Ex "node1:/master/lib/ManufactureRule.mrdb"
# (Windows -> Windows) Ex "N:\\master\\lib\\ManufactureRule.mrdb"
ManufactureRule {
# Panel Template directory path
PanelTemplate {
# write pathname here. Ex "N:\\master\\lib\\paneltemplate\\"
可以任意指定路径
 楼主| 发表于 2006-1-13 10:37:38 | 显示全部楼层
谢谢斑竹
GMT+8, 2024-5-2 17:54 , Processed in 0.128510 second(s), 19 queries .
