感兴趣的可以上laogu瞧瞧去,一定有新发现的。[em01]
____________ ____________ __________ / ____ \ / ____ \ / __ \ / / \_// / \_// / \ \ / /___ / /___ / /____\ \ / ____/ / ____/ / _______ \ / / _ / / / / \ \ / /____/ \/ / / / \ \ \_____________/\_____/ \_____/ \___\ +-----------+ E.F.A. .T.E.A.M. .2.0.0.6 +-----------+
EDA FOR ALL Group Present : 苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘
Mentor Graphics PADS 2005 SPac2 Build 266.2
苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘? 策 卟 ? SUPPLIER : TEAM EFA RELEASE DATE : 04-Jan-2005 ? ? CRACKER : TEAM EFA #'s Files : 1 CD ? 懿 PACKAGER : TEAM EFA PROTECTION : FlexLM 8.2 曹 ? _苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘躝 ? 遀曹? ?躝 _?? 苘睻? 卟UUU睻U曹苘 苘策 卟苘 苘懿UU睻UU策 U?? 哌睻UUUU R E L E A S E N O T E S UUUUU策? ?睻 哌 睻UUU UUUU? 哌 哌哌策哌 懿?睻U 哌哌哌哌哌哌哌哌哌哌哌哌哌哌哌哌策?UU?卟?哌哌哌? 哌曹 懿哌 達 _?
Here is another one from us...........
PADS2005 SPac2 Release Highlights
Introduction
As the third major release for 2005, PADS2005 SPac2 continues to demonstrate Mentor Graphics ongoing commitment to this product line with GUI standardization across the PADS tools including a new Project Explorer for PADS Logic and PADS Layout, and further usability and intra-tool integration. Other enhancements include functions formerly known as the Analog Toolkit option, as standard for every PADS Layout configuration. A newly integrated OrCAD schematic and library import function has been added to PADS Logic. In addition, this release introduces the new Mentor Stardard Installer (MSI) which includes all products found in the PADS Flow.
As with all releases, it also includes a significant number of defect fixes, see the Release Notes on the web.
? _苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘苘躝 ? 遀曹? ?躝 _?? 苘睻? 卟UUU睻U曹苘 苘策 卟苘 苘懿UU睻UU策 U?? 哌睻UUUU I N S T A L L N O T E S UUUUU策? ?睻 哌 睻UUU UUUU? 哌 哌哌策哌 懿?睻U 哌哌哌哌哌哌哌哌哌哌哌哌哌哌哌哌策?UU?卟?哌哌哌哌 ? 哌曹 懿哌 ? 達 _?
1- Use the makelic facility under KeyGen folder to make a working license for your machine. Save it to a known place.
2- Install the programs by inserting the CD or running Setup.
3- When asked, point to the generated license.txt in item 1.
4- Select what you want to intall.
5-
NB.: PADS2005 SPac2 has been fully tested on Windows XP service pack 2. When Windows XP service pack 2 is installed on a license server, PADS end users may not be able to check out floating licenses from the license server. This happens because the Windows Firewall (Internet Connection Firewall or ICF) is turned on by default. You must disable the firewall or setup the lmgrd.exe and mgcld.exe as exception processes, for floating licensing to work correctly. |
