高速DDR PCB设计中的时序分析 A)DDR System Implementation Guidelines: Since DDR devices using a 200MHz clock (“DDR400”) are used, the memory architecture provides a theoretical peak bandwidth of: 2 (controllers) * 4 (bytes/controller) * 400 (Mtransfers/sec) = 3.2 Gbytes/sec Key features of this topology include the following: 1. All data signals (DQ, DQS, DM) can be routed with a maximum trace length of 1500mils or less. 2. All address, command, and clock signals can be routed with a maximum trace length of 2000 mils or less. 3. Series termination – nominal 33 ohms – is recommended for all DRAM signals 4. Differential clock signals should be routed as a differential pair, targeted for a differential impedance of 100 ohms (each clock trace 50 ohms) 5. Designs should use the following PCB track width and clearance rules: Signal Group Track Width Clearance DQSx 5 10 CK/CK# Target to 100R differential impedance 10 All others 5 5 B) 6层板参考层结构为:信号1(顶)、地平面、信号2 信号3 电源平面、信号4(底)。各层间距依次可为8mil 8mil 14mil 8mil 8mil。 假定板材介电常数4.2, 铜厚1oz 芯片之间的走线长度估计在2500-3500mil左右, 匹配采用串联终端的匹配, 芯片数据手册如图. 怎样进行时钟和数据的信号完整性进行分析仿真?
